Configures VLAN L2PT profiles on service interfaces.
| vlan | Specifies the VLAN configuration. |
| vlan_name | Specifies the VLAN name. |
| vxlan | Specifies Virtual eXtensible LAN. |
| vr | Specifies Virtual Router. |
| vr_name | Specifies the Virtual Router Name. If not specified, the VR of the current command context is used. |
| rtep | Specifies Remote Tunnel End Point. |
| rtep_ipv4 | Specifies the Remote Tunnel End Point IPv4 address. |
| l2pt | Specifies Layer 2 protocol tunneling. |
| profile | Specifies the L2PT profile for the RTEP. |
| none | Specifies that no L2PT profile should be bound to the ports (default). |
| profile_name | Specifies the L2PT profile to be bound to the ports. |
Disabled.
Use this command to configure VLAN L2PT profiles on VXLAN RTEP interfaces.
The following example binds the tenant VLAN to l2pt-nw profile with RTEP IP address as 2.2.2.2 of VxLAN service Interface with the action "none":
# configure l2pt profile "l2pt-nw" add protocol filter cdp action none # configure vlan tenant vxlan rtep 2.2.2.2 l2pt profile l2pt-nw
The following example unbinds the configured l2pt profile from RTEP IP address 2.2.2.2 associated with tenant VLAN:
# configure vlan tenant vxlan rtep 2.2.2.2 l2pt profile none
The following example binds the tenant with peer 2.2.2.2 of VxLAN RTEP l2pt-nw specifies tunneling actions:
# configure l2pt profile "l2pt-nw" add protocol filter cdp action tunnel # configure tenant vxlan rtep 2.2.2.2 l2pt profile "l2pt-nw" Error: Cannot tunnel on VxLAN RTEP. Tunnel action may be applied only to ports.
This command was first available in ExtremeXOS 31.3.
This command is supported on the ExtremeSwitching 5520 series switch and stacks with 5520 slots only.
